stm32e with USB-232 driver
ng_tengjie
Posted on January 21, 2011 at 10:11
3 REPLIES 3
Posted on May 17, 2011 at 14:22
No you probably need to be looking at finding a serial zigbee module. Connect it to one of the serial ports. And write you own driver software.
''I need a USB-RS232 converter to physically connect the dongle''
You mean it's a USB dongle?
In that case, you would need to provide a USB Host for it.
As Clive1 says, you would be far better off using a Zigbee module with a UART, SPI, or similar interface...
ng_tengjie
Thanks for the replies! :) Will search for a dongle with serial interface then..
tj
