STM32CubeMX project reuse
marcopiovesan9
Posted on September 26, 2017 at 17:56
If I have .ioc project for a UFBGA176 and then I want to migrate to an LQFP144, is there a way to proceed with STM32CubeMX without loosing all the work in 'Configuration' tab?
In other words is there a way to separate pinout configuration from other configurations?
Thank you
Marco
Imen.D
Posted on September 26, 2017 at 18:18
You can migrate your project and load the current configuration to another compatible MCU. For that, p
lease follow steps in the
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
Tutorial 5 :
exporting current project configuration to a compatible MCU'
Kind Regards
Imen
Imen
Posted on October 31, 2017 at 18:11
Yes, I know this command and I did an attempt before asking. My problem is that in the list of compatible MCU I have just UFBGA176 units while I need migration to an LQFP144 package unit of the same family.
Probably the exporting function miss the capability to migration from packages with different pin-count.
Did I get it right ?
Thank you
Marco
