stm32cubemx init SDRAM in STM32F429NI
drachev
Posted on March 03, 2016 at 07:28
Hello.
CubeMX not correct settings SDRAM, when use 2 chip.
CubeMX create next not work code:
/* FMC initialization function */
void MX_FMC_Init(void)
  FMC_SDRAM_TimingTypeDef SdramTiming;
  /** Perform the SDRAM1 memory initialization sequence
  hsdram1.Instance = FMC_SDRAM_DEVICE;
  /* hsdram1.Init */
  hsdram1.Init.SDBank = FMC_SDRAM_BANK1;
  hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
  hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
  hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
  hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
  hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
  hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
  hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
  hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE;
  hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1;
  /* SdramTiming */
  SdramTiming.LoadToActiveDelay = 2;
  SdramTiming.ExitSelfRefreshDelay = 7;
  SdramTiming.SelfRefreshTime = 4;
  SdramTiming.RowCycleDelay = 7;
  SdramTiming.WriteRecoveryTime = 3;
  SdramTiming.RPDelay = 2;
  SdramTiming.RCDDelay = 2;
  HAL_SDRAM_Init(&hsdram1, &SdramTiming);
  /** Perform the SDRAM2 memory initialization sequence
  hsdram2.Instance = FMC_SDRAM_DEVICE;
  /* hsdram2.Init */
  hsdram2.Init.SDBank = FMC_SDRAM_BANK2;
  hsdram2.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
  hsdram2.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
  hsdram2.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
  hsdram2.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
  hsdram2.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
  hsdram2.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
  hsdram2.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
  hsdram2.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE;
  hsdram2.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1;
  /* SdramTiming */
  HAL_SDRAM_Init(&hsdram2, &SdramTiming);
Need befor Init sdram2, then init sdram1.
Next cod is work:
  /* hsdram2.Init */
  /* SdramTiming */
  /* hsdram1.Init */
  /* SdramTiming */
I hope you resolve the problem and make a little better cubeMX.
Amel NASRI
Posted on March 08, 2016 at 10:14
Hi drachev.andrei,
Your case is reported internally for further investigation.
You will be updated if there are more details to add on this regard.
-Mayla-
stm32cube-t
Posted on March 18, 2016 at 09:21
Dear user,
Thank you for reporting this issue. Your workaround is correct.
The root cause has been found in the HAL driver implementation and shall be fixed a.s.a.p.:
The SDRAM2 configuration is clearing the whole configuration of bank1 when it should only take care of the parameters for both banks(clock period, burst...): these parameters are configured in SDCR1 register.
Best regards
