STM32CubeMX generated project files enable "Parallel build" by default?
kurta999
Nowadays nobody has single core CPU where project is building, so this option should be enabled by default, or configurable in CubeMX.
kurta999
Looks like this "issue (not really an issue..)" is already solved in STM32CubeIDE, paraller build is on by default.
Thanks!
kurta999
Any toughts?
Not exactly hard to click in Keil, or turning off browse information so it doesn't run like a compiler from 1985.
Personally use multi-core here so I can do OTHER things while the build occurs rather than saturate all of them.
kurta999
Thanks!
