STM32CubeMX freezes when generating code
njansen1
Posted on August 11, 2015 at 10:26
STMCubeMX is freezing every time I try to generate code for an STM32F429 project.  This is my first time using it, but everything so far has been pretty straightforward, and I haven't given it any crazy parameters that would seem unreasonable.
The exact steps to reproduce the problem are: Load the IOC file (pasted below).  Click Project -> Generate Code.  It will display a progress bar, and will basically stay there forever (hours, etc).  I've tried it several times, and it does the same thing every time.
I will try re-generating the project and trying that, but figured I'd post this here to see if anyone else has had the problem, and to see if anyone here could re-create the problem.
Here's my 'STMF429ZETx.ioc' file:
http://pastebin.com/8hR9gveS
And an image of the app, in its frozen state:
http://imgur.com/pOawxyl
Oh, my OS platform is Windows 8 on a pretty standard Lenovo laptop.  My Java JRE version is 8.0.51.16.
Any help would be appreciated.
Thanks!
6 REPLIES 6
Posted on August 11, 2015 at 11:12
Hi jansen.neil,
Which version of CubeMx are using? The last one is 4.9.0.
Could you change your machine?
-Shahrzad-
njansen1
Posted on August 11, 2015 at 16:26
STM32CubeMX version is 4.9.0.
I made a new project and tried to duplicate the settings section by section, and it actually worked (didn't freeze), although I'm not sure why.  If I do a diff on the two *.ioc's they differ, but I can't figure out why one would work but the other one would make it crash.  Either way, I guess it's working now.
I'm still having a problem getting the project imported into either Rowley CrossWorks or ac6 SystemsWorkbench.  I've not been able to get either of them to compile.  Will spend a few more hours on it to make sure it's not anything stupid that I'm doing.. then I might be back for more help.  This whole process has been extremely daunting but will hopefully worth it in the end.
njansen1
Posted on August 13, 2015 at 07:48
Now when I open up my new file, it still freezes up.
This is extremely frustrating and causing me to lose a lot of time.  STM32CubeMX should not just lock up like this.  It's clearly a bug or some unhanded corner case, but unfortunately there's not much else that I can do at this point.
Can someone possibly reproduce this behavior on their machine?  Is there any more information that I can provide to help track this down?  Are there older versions that may be more stable?  Is there anything else that I might be doing wrong?
Amel NASRI
Posted on August 13, 2015 at 10:37
Hi jansen.neil,
Your .ioc file is needed in order to try to reproduce your issue. Could you please share it?
-Mayla-
njansen1
Posted on August 15, 2015 at 14:56
You will find a link to the .ioc file in my first post.
Posted on August 21, 2015 at 16:43
Hi jansen.neil,
I generated a project with your .ioc file  on SW4STM, I compiled it and I did not have any compilation error.
Try to re-instal SW4STM and make right steps to setting the path of your project.
Sorry to not be able to help you more.
-Shahrzad-
