STM32Cubemx 4.24.0 F1 series RTC module bug
‎2018-01-23 4:26 PM
STM32CubeMX upgrade to 4.24.0 version, STM32F1 series RTC module will be garbled. Unable to compile.
the details as attached file.
‎2018-03-20 9:45 AM
Hello
Hu.Bruno
,This issue is now fixed in the current CubeMX release.
Please, upgrade with CubeMX4.25 if not already done.
BR. Jeanne
‎2018-01-24 3:02 AM
‎2018-01-26 10:39 PM
Steps
1) Set the chip model stm32f1 series2) stm32cubemx project-> setting-> code generator-> Generate files3) Check 'Generate peripheral initialization as a pair of '.c / .h / files per peripheral'4) Check Pinout-> RTC-> Activate Clock Source5) generate a separate rtc.c file, open the rtc.c file, the file internal error- Mark as New
‎2018-01-30 2:11 AM
Hello
Hu.Bruno
,First I thank you for your bug report.
I confirm this bug, and the correction will be integrated in CubeMX4.
You can refer to the following post, and its answer, to see how to correct it in the mean time.
https://community.st.com/0D50X00009XkgPESAZ
Kind regards
Sirma
‎2018-03-20 9:45 AM
Hello
Hu.Bruno
BR. Jeanne
