STM32CubeIDE adding code to main.c - code disappears
‎2022-11-08 1:27 AM
Is there a rule where to put code into main.c so that it stays there permanently? It happended to me now a couple of times that I added an interrupt callback function which suddenly disappeared. Are there areas in main.c where to safely put those?
‎2022-11-08 2:49 AM
Hello @chriskuku​,
You should add the functions in the User Code section:
/* USER CODE BEGIN */
/* USER CODE END */
Ensure that following option is checked: "Keep User Code when re-generating". In this case, the user sections defined by STM32CubeMX are preserved.
Note that when upgrading to a new version of STM32CubeMX, make sure to always backup your projects before loading the new project (especially when the project includes user code).
I hope that this brings some help to you.
Foued
‎2022-11-08 2:49 AM
Hello @chriskuku​,
/* USER CODE END */
Foued
