2017-07-24 05:41 PM
Joystick does not work and does not recognize usb.
Whether it's a board issue or a programming problem..
Is there someone who solved it?
2017-08-02 02:08 PM
Hello
dmy
,Can you please provide more details that can give us
enough insight into
what you are doing, and how?Did you follow the instructions in the readme.txt file? Which Cube version do you use? Have you made a change in the exapmle?
Best Regards
Imen
