stm32cubef4/stm32469i_eval/Application/Audio is not working
dmy dmy
Posted on July 25, 2017 at 02:41
Joystick does not work and does not recognize usb.
Whether it's a board issue or a programming problem..
Is there someone who solved it?
1 REPLY 1
Imen.D
Posted on August 02, 2017 at 23:08
Hello
dmy
Can you please provide more details that can give us
enough insight into
what you are doing, and how?
Did you follow the instructions in the readme.txt file? Which Cube version do you use? Have you made a change in the exapmle?
Best Regards
Imen
Imen
