STM32Cube Bug - FMC write recovery time
2016-07-04 3:50 AM
STM32CubeMX: 4.15.1
STM32CubeF7: 1.4.0 MCU: STM32F746NGHx In the setting: ''Configuration | FMC | SDRAM1 | SDRAM timing in memory clock cycles | Write recovery time'' the value is constrained in [3,16] (and the help agrees with that). However, it doesn't agree with the library code (stm32f7xx_ll_fmc.h:288): #define IS_FMC_WRITE_RECOVERY_TIME(__TIME__) (((__TIME__) > 0) && ((__TIME__) <= 16))- Mark as New
2016-07-04 7:13 AM
From my side, I have in CubeMx: ''WriteRecoveryTime1 must be between 1 and 16'' (as shown in the attached screen).Could you please put your screen to have more idea about these parameters and configuration's.
Regards ________________ Attachments : Capture.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htov&d=%2Fa%2F0X0000000aXG%2F_F4ii7Kmf5XwOieXeGuq_vV.Kz8HNYuXSOQ5rCRHK9s&asPdf=false- Mark as New
2016-07-10 11:13 PM
Attached is my FMC dialog. Do the limits depend on other parameters?
________________ Attachments : bug_FMC.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htp0&d=%2Fa%2F0X0000000aXH%2F7gbBVoy979q8A.5lv9bErmMzBltJA.YlpW0lRKxpoW8&asPdf=false- Mark as New
2016-07-21 1:42 AM
Dear user,
As stated in the user manual, we have the following condition:
TWR >
TRAS - TRCD
Which means within STM32CubeMX user interface: the write recovery time must be greater than (Self-refresh time - Row to colum delay).
Playing with the values of self-refresh time (increase) and row to column delay (decrease) , you can reach again the lowest bound value of 1 for the Write recovery time.
Best regards
