STM324x9I-Eval : Trace Configuration
Options
‎2015-02-23 2:53 PM
Posted on February 23, 2015 at 23:53
Hello everyone,
I juste received an ulinkpro so I can use the ETM feature later on in my development. Right now, I am trying to simply display a variable in the logic analyzer but I get no synchronization. I read that we must link a .ini file to configure the board for traces.Anyone has already done it? What should I do.Regards,Keaven #stm324x9i-eval-trace-ulinkpro
Labels:
- Labels:
STM32F4 Series
3 REPLIES 3
Options
‎2015-02-23 3:45 PM
Posted on February 24, 2015 at 00:45
Read the manual(s), talk to Keil support? Have done for the MCBSTM32F400, needed to jumper the high order address pins so they go to the trace header, not the external memories. Create a debugger script (.INI) to bring up the board. So you'd definitely want to read the board manual and know exactly what jumpers or solder bridges need setting.
Options
‎2015-02-23 4:01 PM
Posted on February 24, 2015 at 01:01
C:\Keil470\ARM\Boards\Keil\MCBSTM32F400\Blinky_ULp\STM32F4xx_TP.ini
/* STM32_TP.ini: STM32 Debugger Initialization File */
Use
Configuration Wizard in Context Menu >>> //
/* This file is part of the uVision/ARM development tools. */
/* Copyright (c) 2005-2011 Keil Software. All rights reserved. */
/* This software may only be used under the terms of a valid, current, */
/* end user licence from KEIL for a compatible version of KEIL software */
/* development tools. Nothing else gives you the right to use this software. */
FUNC void DebugSetup (void) {
_WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000010); // RCC_AHB1ENR: IO port E clock enable
_WDWORD(0x40021000, 0x00002AA0); // GPIOE_MODER: PE2..PE6 = Alternate function mode
_WDWORD(0x40021008, 0x00003FF0); // GPIOE_OSPEEDR: PE2..PE6 = 100 MHz speed
_WDWORD(0x4002100C, 0x00000000); // GPIOE_PUPDR: PE2..PE6 = No Pull-up/Pull-down
_WDWORD(0x40021020, 0x00000000); // GPIOE_AFRL: PE2..PE6 = AF0
h
> Debug MCU Configuration
o1.0
> DBG_SLEEP <
i
> Debug Sleep Mode
o1.1
> DBG_STOP <
i
> Debug Stop Mode
o1.2
> DBG_STANDBY <
i
> Debug Standby Mode
o1.5
> TRACE_IOEN <
i
> Trace I/O Enable
o1.6..7
> TRACE_MODE <
i
> Trace Mode
0
=> Asynchronous
1
=> Synchronous: TRACEDATA Size 1
2
=> Synchronous: TRACEDATA Size 2
3
=> Synchronous: TRACEDATA Size 4
h
_WDWORD(0xE0042004, 0x000000E7); // DBGMCU_CR
h
> Debug MCU APB1 Freeze
o1.0
> DBG_TIM2_STOP <
i
> Timer 2 Stopped when Core is halted
o1.1
> DBG_TIM3_STOP <
i
> Timer 3 Stopped when Core is halted
o1.2
> DBG_TIM4_STOP <
i
> Timer 4 Stopped when Core is halted
o1.3
> DBG_TIM5_STOP <
i
> Timer 5 Stopped when Core is halted
o1.4
> DBG_TIM6_STOP <
i
> Timer 6 Stopped when Core is halted
o1.5
> DBG_TIM7_STOP <
i
> Timer 7 Stopped when Core is halted
o1.6
> DBG_TIM12_STOP <
i
> Timer 12 Stopped when Core is halted
o1.7
> DBG_TIM13_STOP <
i
> Timer 13 Stopped when Core is halted
o1.8
> DBG_TIM14_STOP <
i
> Timer 14 Stopped when Core is halted
o1.10
> DBG_RTC_STOP <
i
> RTC Stopped when Core is halted
o1.11
> DBG_WWDG_STOP <
i
> Window Watchdog Stopped when Core is halted
o1.12
> DBG_IWDG_STOP <
i
> Independent Watchdog Stopped when Core is halted
o1.21
> DBG_I2C1_SMBUS_TIMEOUT <
i
> I2C1 SMBUS Timeout Mode Stopped when Core is halted
o1.22
> DBG_I2C2_SMBUS_TIMEOUT <
i
> I2C2 SMBUS Timeout Mode Stopped when Core is halted
o1.23
> DBG_I2C3_SMBUS_TIMEOUT <
i
> I2C3 SMBUS Timeout Mode Stopped when Core is halted
o1.25
> DBG_CAN1_STOP <
i
> CAN1 Stopped when Core is halted
o1.26
> DBG_CAN2_STOP <
i
> CAN2 Stopped when Core is halted
h
_WDWORD(0xE0042008, 0x00000000); // DBGMCU_APB1_FZ
h
> Debug MCU APB2 Freeze
o1.0
> DBG_TIM1_STOP <
i
> Timer 1 Stopped when Core is halted
o1.1
> DBG_TIM8_STOP <
i
> Timer 8 Stopped when Core is halted
o1.16
> DBG_TIM9_STOP <
i
> Timer 9 Stopped when Core is halted
o1.17
> DBG_TIM10_STOP <
i
> Timer 10 Stopped when Core is halted
o1.18
> DBG_TIM11_STOP <
i
> Timer 11 Stopped when Core is halted
h
_WDWORD(0xE004200C, 0x00000000); // DBGMCU_APB2_FZ
// Executed after reset via uVision's 'Reset'-button
FUNC void OnResetExec (void) {
DebugSetup();
DebugSetup(); // Debugger Setup
Options
‎2015-02-24 6:53 AM
Posted on February 24, 2015 at 15:53
Thank you Clive1,
I found some example of debug file for STM32437I-Eval which has the same MCU and looks close to what I have . I will look into it.Will contact Keil for other side of the problem.Thank you
