STM3210VE, 8G SD card , SDIO 4bits bus, DMA mode-STOne-32,help me please
‎2010-09-16 06:07 PM
‎2011-05-17 05:07 AM
Is R/W SDHC card by SDIO in DMA 4bits mode not s
table
? Are you sure the high capacity cards use the same protocol as the older/slower cards? I'm pretty these cards won't work in classic readers either.Up vote any posts that you find helpful, it shows what's working..
thanks for your reply,
This code can judge the type of cards...and i readed the spec: Part_1_Physical_Layer_Simplified_Specification_Ver3.01_Final_100518.pdf and SD_SDIO_specsv1.pdfThe Process
of the code is right for the spec.. And all of the Response for the CMD is right.../* CMD8: SEND_IF_COND --------------------------------------------------------*/
/* Send CMD8 to verify SD card interface operating condition */ /* Argument: - [31:12]: Reserved (shall be set to '0') - [11:8]: Supply Voltage (VHS) 0x1 (Range: 2.7-3.6 V) - [7:0]: Check Pattern (recommended 0xAA) */ /* CMD Response: R7 */ SDIO_CmdInitStructure.SDIO_Argument = SD_CHECK_PATTERN; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SEND_IF_COND; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp7Error();
if (errorstatus == SD_OK)
{ CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /* SD Card 2.0 */ SDType = SD_HIGH_CAPACITY; } else { /* CMD55 */ SDIO_CmdInitStructure.SDIO_Argument = 0x00; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure); errorstatus = CmdResp1Error(SDIO_APP_CMD); }- Mark as New
I am crazy.who can tell me some c
lue
?- Mark as New
越�?�越晕乎了。。。真是的,这问题�?�的,SANDISKçš„8G SDHC�?�,�?�尔能写,但是文件里�?�大部分的数�?�都是错的。。晕。。。2G的完全æ£ç¡®
Dear lin,
I will be back to you soon, i need to investigate the case and reproduce it first. Cheers, STOne-32.- Mark as New
//Now i describe my code to you,and i think there are some bugs in the
//examples which come from st. SD_Error SD_PowerON(void) { SD_Error errorstatus = SD_OK; uint32_t response = 0, count = 0; bool validvoltage = FALSE; uint32_t SDType = SD_STD_CAPACITY; uint8_t i = 0;/* Power ON Sequence -------------------------------------------------------*/
/* Configure the SDIO peripheral */ SDIO_InitStructure.SDIO_ClockDiv = SDIO_INIT_CLK_DIV; /* HCLK = 72MHz, SDIOCLK = 72MHz, SDIO_CK = HCLK/(178 + 2) = 400 KHz */ SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising; SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable; SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable; SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b; SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable; SDIO_Init(&SDIO_InitStructure);/* Set Power State to ON */
SDIO_SetPowerState(SDIO_PowerState_ON);/* Enable SDIO Clock */
SDIO_ClockCmd(ENABLE);/* CMD0: GO_IDLE_STATE -------------------------------------------------------*/
/* No CMD response required */ SDIO_CmdInitStructure.SDIO_Argument = 0x0; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_GO_IDLE_STATE; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_No; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; // it will be TimeOut if i don't add this,It needs 74 clocks here //according to the SD spec // for( i = 0 ; i < 74 ; i++) { SDIO_SendCommand(&SDIO_CmdInitStructure); errorstatus = CmdError(); }if (errorstatus != SD_OK)
{ /* CMD Response TimeOut (wait for CMDSENT flag) */ return(errorstatus); }/* CMD8: SEND_IF_COND --------------------------------------------------------*/
{ CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /* SD Card 2.0 */ SDType = SD_HIGH_CAPACITY; } else { /* CMD55 */ SDIO_CmdInitStructure.SDIO_Argument = 0x00; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure); errorstatus = CmdResp1Error(SDIO_APP_CMD); } /* CMD55 */ SDIO_CmdInitStructure.SDIO_Argument = 0x00; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure); errorstatus = CmdResp1Error(SDIO_APP_CMD);/* If errorstatus is Command TimeOut, it is a MMC card */
/* If errorstatus is SD_OK it is a SD card: SD card 2.0 (voltage range mismatch) or SD card 1.x */ if (errorstatus == SD_OK) { /* SD CARD */ /* Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */ while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL)) {/* SEND CMD55 APP_CMD with RCA as 0 */
SDIO_CmdInitStructure.SDIO_Argument = 0x00; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp1Error(SDIO_APP_CMD);
{ return(errorstatus); } SDIO_CmdInitStructure.SDIO_Argument = SD_VOLTAGE_WINDOW_SD | SDType; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SD_APP_OP_COND; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp3Error();
if (errorstatus != SD_OK) { return(errorstatus); }response = SDIO_GetResponse(SDIO_RESP1);
validvoltage = (bool) (((response >> 31) == 1) ? 1 : 0); count++; } if (count >= SD_MAX_VOLT_TRIAL) { errorstatus = SD_INVALID_VOLTRANGE; return(errorstatus); }if (response &= SD_HIGH_CAPACITY)
{ CardType = SDIO_HIGH_CAPACITY_SD_CARD; }}/* else MMC Card */
}- Mark as New
//I cannot open the bbs this morning,Now it's ok.I can go on.
//In this function,It have be right since i add some code followed: static SD_Error FindSCR(uint16_t rca, uint32_t *pscr) { uint16_t delay_time = 0; uint32_t index = 0;/************************/
// uint32_t temp = 0, temp_go = 0; /************************/SD_Error errorstatus = SD_OK;
uint32_t tempscr[2] = {0, 0};/* Set Block Size To 8 Bytes */
/* Send CMD55 APP_CMD with argument as card's RCA */ SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)8; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SET_BLOCKLEN; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp1Error(SDIO_SET_BLOCKLEN);
{ return(errorstatus); }/* Send CMD55 APP_CMD with argument as card's RCA */
SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) RCA << 16; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp1Error(SDIO_APP_CMD);
{ return(errorstatus); } SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT; SDIO_DataInitStructure.SDIO_DataLength = 8; SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DataBlockSize_8b; SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToSDIO;SDIO_DataInitStructure.SDIO_TransferMode = SDIO_TransferMode_Block;
SDIO_DataInitStructure.SDIO_DPSM = SDIO_DPSM_Enable;
SDIO_DataConfig(&SDIO_DataInitStructure);/************************/// It needs sometimes.
for(delay_time = 0 ; delay_time < 20 ;delay_time++)
{ __nop(); }/************************/
/* Send ACMD51 SD_APP_SEND_SCR with argument as 0 */
SDIO_CmdInitStructure.SDIO_Argument = 0x0; SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SD_APP_SEND_SCR; SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No; SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable; SDIO_SendCommand(&SDIO_CmdInitStructure);errorstatus = CmdResp1Error(SDIO_SD_APP_SEND_SCR);
{ return(errorstatus); }/*******************************/
//temp = SDIO->STA;//清除STAæ ‡å¿—ï¿½?,�?�测试用
//temp_go = temp + 1;/*******************************/
while (!(SDIO->STA & (SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND | SDIO_FLAG_STBITERR)))
{ if (SDIO_GetFlagStatus(SDIO_FLAG_RXDAVL) != RESET) { *(tempscr + index) = SDIO_ReadData(); index++;/*********************/// It need jump out. if(2 == index) { break; } /*********************/}
}if (SDIO_GetFlagStatus(SDIO_FLAG_DTIMEOUT) != RESET)
{ SDIO_ClearFlag(SDIO_FLAG_DTIMEOUT); errorstatus = SD_DATA_TIMEOUT; return(errorstatus); } else if (SDIO_GetFlagStatus(SDIO_FLAG_DCRCFAIL) != RESET) { SDIO_ClearFlag(SDIO_FLAG_DCRCFAIL); errorstatus = SD_DATA_CRC_FAIL; return(errorstatus); } else if (SDIO_GetFlagStatus(SDIO_FLAG_RXOVERR) != RESET) { SDIO_ClearFlag(SDIO_FLAG_RXOVERR); errorstatus = SD_RX_OVERRUN; return(errorstatus); } else if (SDIO_GetFlagStatus(SDIO_FLAG_STBITERR) != RESET) { SDIO_ClearFlag(SDIO_FLAG_STBITERR); errorstatus = SD_START_BIT_ERR; return(errorstatus); }/* Clear all the static flags */
SDIO_ClearFlag(SDIO_STATIC_FLAGS);*(pscr + 1) = ((tempscr[0] & SD_0TO7BITS) << 24) | ((tempscr[0] & SD_8TO15BITS) << 8) | ((tempscr[0] & SD_16TO23BITS) >> 8) | ((tempscr[0] & SD_24TO31BITS) >> 24);
*(pscr) = ((tempscr[1] & SD_0TO7BITS) << 24) | ((tempscr[1] & SD_8TO15BITS) << 8) | ((tempscr[1] & SD_16TO23BITS) >> 8) | ((tempscr[1] & SD_24TO31BITS) >> 24);
}- Mark as New
And i found some problems when i use the 2G SD_Card:
f_open( );f_write( );f_close(); ---->I must write this functions together,otherwise there will be some wrong data in the file.like this: Write_Something() { f_open( ...); f_write( ...); f_close(....); } It will be wrong if it be writed followed: Write_Something() { f_open( ...); delay(sometimes);//or do otherthings f_write( ...); delay(sometimes);//or do otherthings f_close(....); }- Mark as New
Many e
ngineer
s in china said that they have various problems when using the ''SDIO+4bit+DMA''mode.''Some cards cannot R/W in this mode'',they said. So,most of them choose the ''SPI'' mode, But i cann't,I must solve this problem....
