STM32 Series - Calculations of Timer Variables.
‎2014-10-04 7:02 PM
This is a subject that seems to have a lot of confusion (I do not fully understand). How to calculate the Variables:
- Period
- Prescaler
- Duration
if only a few other variables are known. At higher frequencies, for example 1000000Hz simple rules work. At lower Frequencies like 1281Hz things get a little more complicated.
As an example: if we aim for an output frequency of 1281Hz, we need to set the ARR Register to: 32785. We need to set the PSC Register to: 3 and if we want a 50% DutyCycle, we need to set the CCRx Register to: 16393. Where the x in CCRx is the specified Channel one is going to use. 1, 2, 3 or 4. The Registers need to see values of 16 BITs, Integer Values(65535 or less). Equations exist so calculations can be made, for example: TIM_Update_Frequency(Hz) = Clock / (PSC - 1) * (Period - 1) 1281.11273792094 = 84000000 / ((3) * (32785)) now, the problem becomes more complicated, for a desired frequency of 840Hz: 425.946209078739 = 84000000 / ((167) * (1189)) Here in lies the problem, how does one find the value of PSC when one knows only the values for ''Clock'' and ''Period''? The value ''TIM_Update_Frequency(Hz)'' is not always the actual Desired Frequency. Other equations must exist so as to calculate the ''PSC'' Value, or to calculate the ''TIM_Update_Frequency(Hz)'' so as to deduce the other values. Guess work is just not a logical approach here. Can anyone help with more equations for solving for the other variables? Thank you Chris #factoring!- Mark as New
‎2014-10-06 2:21 AM
using
System;
using
System.Linq;
using
System.Text;
using
System.Collections.Generic;
namespace
ConsoleApplication1
class
Program
#region Fields...
// For Debugging Purposes...
private
static
bool
debug =
true
private
static
uint
m_period;
private
static
ScaleFactor m_scale;
private
Clock m_busclock;
private
static
uint
m_prescaler;
private
static
uint
m_duration;
private
static
bool
m_invert;
#endregion
#region Properties...
public
Clock ClockSpeed
get
return
m_busclock; }
set
{ m_busclock = value; }
public
double
Frequency
get
return
FrequencyFromPeriod((
double
)m_period, m_scale);
set
m_period = PeriodFromFrequency(value,
out
m_scale);
//this.Commit();
public
uint
Prescaler
get
return
m_prescaler; }
set
{ m_prescaler = value; }
public
uint
Period
get
return
m_period;
set
m_period = value;
//this.Commit();
public
double
DutyCycle
get
return
DutyCycleFromDurationAndPeriod((
double
)m_period, (
double
)m_duration);
set
m_duration = DurationFromDutyCycleAndPeriod(value, (
double
)m_period);
//this.Commit();
public
uint
Duration
get
return
m_duration;
set
m_duration = value;
//this.Commit();
public
bool
InvertPin
get
return
m_invert; }
set
{ m_invert = value; }
public
ScaleFactor Scale
get
return
m_scale;
set
m_scale = value;
//this.Commit();
#endregion
public
enum
ScaleFactor :
uint
Microseconds = 0xf4240,
Milliseconds = 0x3e8,
Nanoseconds = 0x3b9aca00
public
enum
Clock :
uint
// [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20Series%20-%20Calculations%20of%20Timer%20Variables&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https%3a//my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx¤tviews=22]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex%5fmx%5fstm32%2fSTM32%20Series%20%2d%20Calculations%20of%20Timer%20Variables&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex%5Fmx%5Fstm32%2FAllItems%2Easpx¤tviews=22
// See: Post: 10/5/2014 2:43 PM
// On the F4 running at 168 MHz, APB1 is typically 42 MHz (DIV4) and APB2 84 MHz (DIV2),
// and the respective TIMCLKs are 84 MHz, and 168 MHz...
APB1 = 84000000,
APB2 = 168000000
static
void
Main(
string
[] args)
double
Frequency = 1840;
double
DucyCycle = 0.5;
CalculateValues(Frequency, DucyCycle);
Console.ReadLine();
private
static
void
CalculateValues(
double
frequency_Hz,
double
dutyCycle)
m_period = PeriodFromFrequency(frequency_Hz,
out
m_scale);
m_duration = DurationFromDutyCycleAndPeriod(dutyCycle, (
double
)m_period);
#region Fields...
uint
period = m_period;
uint
duration = m_duration;
double
mperiod = period;
double
mduration = duration;
uint
scale = ((
uint
)m_scale);
uint
clk;
uint
prescaler;
#endregion
#region System Vars...
int
timer = 8;
uint
treg = 0x20000;
uint
PWM1_CLK_HZ;
uint
PWM2_CLK_HZ;
uint
ONE_MHZ = 1000000;
uint
PWM1_CLK_MHZ = 84;
uint
PWM2_CLK_MHZ = 42;
uint
PWM_MAX_CLK_MHZ;
uint
SYSTEM_CYCLE_CLOCK_HZ = 168000000;
// 168MHz
uint
SYSTEM_APB1_CLOCK_HZ = 42000000;
// 42MHz
uint
SYSTEM_APB2_CLOCK_HZ = 84000000;
// 84MHz
if
(SYSTEM_APB1_CLOCK_HZ == SYSTEM_CYCLE_CLOCK_HZ)
PWM1_CLK_HZ = (SYSTEM_APB1_CLOCK_HZ);
else
PWM1_CLK_HZ = (SYSTEM_APB1_CLOCK_HZ * 2);
PWM1_CLK_MHZ = (PWM1_CLK_HZ / ONE_MHZ);
if
(SYSTEM_APB2_CLOCK_HZ == SYSTEM_CYCLE_CLOCK_HZ)
PWM2_CLK_HZ = (SYSTEM_APB2_CLOCK_HZ);
else
PWM2_CLK_HZ = (SYSTEM_APB2_CLOCK_HZ * 2);
PWM2_CLK_MHZ = (PWM2_CLK_HZ / ONE_MHZ);
if
(PWM2_CLK_MHZ > PWM1_CLK_MHZ)
PWM_MAX_CLK_MHZ = PWM2_CLK_MHZ;
else
PWM_MAX_CLK_MHZ = PWM1_CLK_MHZ;
if
(duration > period) duration = period;
// APB2
if
uint
)treg == 0x10000)
clk = PWM2_CLK_HZ;
else
clk = PWM1_CLK_HZ;
#endregion
#region Assign Variables...
prescaler = clk / scale;
// scale in MHz
uint
sm = scale / ONE_MHZ;
if
uint
)treg == 0x10000)
clk = PWM2_CLK_MHZ;
else
clk = PWM1_CLK_MHZ;
#endregion
// set pre, p, & d such that:
// pre * p = PWM_CLK * period / scale
// pre * d = PWM_CLK * duration / scale
Console.WriteLine(
Console.WriteLine(
''Freq: ''
+ frequency_Hz);
Console.WriteLine(
''Pre: ''
+ prescaler);
Console.WriteLine(
''Period: ''
+ mperiod);
Console.WriteLine(
''Clk: ''
+ clk);
Console.WriteLine(
''Scale: ''
+ scale);
if
(prescaler == 0)
if
(period > 0xFFFFFFFF / PWM_MAX_CLK_MHZ)
// avoid overflow
prescaler = clk;
period /= sm;
duration /= sm;
else
Console.WriteLine(
''Setting Values from here...''
prescaler = 1;
period = period * clk / sm;
duration = duration * clk / sm;
else
while
(prescaler > 0x10000)
// prescaler too large
// if (period >= 0x80000000) return false;
prescaler >>= 1;
period <<= 1;
duration <<= 1;
Console.WriteLine(
Console.WriteLine(
''Calculated PSC: ''
+ (((168000000 / ((period) / (1 / frequency_Hz))) + 0.5) - 1));
// *** This is what I need to know, this calculation...
if
(timer != 2 && timer != 5)
// 16 bit timer
while
(period >= 0x10000)
// period too large
// if (prescaler > 0x8000) return false;
prescaler <<= 1;
period >>= 1;
duration >>= 1;
Console.WriteLine(
Console.WriteLine(
''Calculated PSC**: ''
Console.WriteLine(
Console.WriteLine(
''PSC: ''
+ (prescaler) +
'' this value is only sometimes correct and the calculated Prescaler is best used.''
Console.WriteLine(
''ARR: ''
+ (period - 1));
Console.WriteLine(
''CCRx: ''
+ duration);
Console.WriteLine(
private
static
uint
double
f,
out
ScaleFactor scale)
if
(f >= 1000.0)
scale = ScaleFactor.Nanoseconds;
return
uint
)((1000000000.0 / f) + 0.5);
if
(f >= 1.0)
scale = ScaleFactor.Microseconds;
return
uint
)((1000000.0 / f) + 0.5);
scale = ScaleFactor.Milliseconds;
return
uint
)((1000.0 / f) + 0.5);
private
uint
PrescalerFromFrequencyAndClock(
double
f)
return
uint
uint
this
.ClockSpeed)) / (((
this
.Period - 1) / (1 / f)) + 1));
private
static
double
double
period, ScaleFactor scale)
return
double
)scale) / period);
private
static
uint
double
dutyCycle,
double
period)
if
(period <= 0.0)
throw
new
ArgumentException();
if
(dutyCycle < 0.0)
return
0;
if
(dutyCycle > 1.0)
return
1;
return
uint
)(dutyCycle * period);
private
static
double
double
period,
double
duration)
if
(period <= 0.0)
throw
new
if
(duration < 0.0)
return
0.0;
if
(duration > period)
return
1.0;
return
(duration / period);
Needs a good clean up and a real fine tune but at the moment this rough cut works. This is a Snippett from the Microsoft PWM Class and the GHI Source Code.
All the best
Chris
‎2014-10-06 12:03 PM
@waclawek.jan - Thank you for the Document number. I have read many documents on the STM32F4 but have missed this particular one. I don't know how.
Thanks All the best Chris URL:http://www.st.com/web/en/resource/technical/document/application_note/DM00042534.pdf
‎2014-10-06 12:16 PM
Some what of a tidy up:
using
System;
using
System.Text;
using
namespace
ConsoleApplication3
class
Program
#region Fields...
private
static
bool
debug =
true
private
static
uint
m_period;
private
static
private
static
Clock m_busclock;
private
static
uint
m_prescaler;
private
static
uint
m_duration;
private
static
bool
m_invert;
#endregion
public
static
Clock ClockSpeed
get
return
m_busclock; }
set
public
double
Frequency
get
return
double
set
out
m_scale);
public
uint
Prescaler
get
return
m_prescaler; }
set
public
uint
Period
get
return
m_period;
set
m_period = value;
public
double
DutyCycle
get
return
double
)m_period, (
double
)m_duration);
set
double
)m_period);
public
uint
Duration
get
return
m_duration;
set
m_duration = value;
public
bool
InvertPin
get
return
m_invert; }
set
public
ScaleFactor Scale
get
return
m_scale;
set
m_scale = value;
//this.Commit();
#endregion
public
enum
ScaleFactor :
uint
public
enum
Clock :
uint
APB1 = 84000000,
APB2 = 168000000,
static
void
Main(
string
[] args)
double
Frequency = 1840;
double
DucyCycle = 0.5;
Console.ReadLine();
private
static
void
CalculateValues(
double
frequency_Hz,
double
dutyCycle)
out
m_scale);
double
)m_period);
#region Fields...
ClockSpeed = Clock.APB2DIV0;
uint
clk = (
uint
)ClockSpeed;
uint
prescaler;
uint
period = m_period;
uint
uint
scale = ((
uint
)m_scale);
int
timer = 8;
uint
treg = 0x20000;
uint
ONE_MHZ = 1000000;
uint
PWM1_CLK_HZ = (
uint
)Clock.APB2DIV0;
uint
PWM2_CLK_HZ = (
uint
)Clock.APB1DIV0;
uint
PWM1_CLK_MHZ = PWM1_CLK_HZ / ONE_MHZ;
uint
PWM2_CLK_MHZ = PWM2_CLK_HZ / ONE_MHZ;
uint
PWM_MAX_CLK_MHZ;
if
else
// Scale in MHz...
uint
scaleMHz = scale / ONE_MHZ;
if
if
uint
)treg == 0x10000)
clk = PWM2_CLK_MHZ;
else
clk = PWM1_CLK_MHZ;
#endregion
Console.WriteLine(
Console.WriteLine(
''Freq: ''
+ frequency_Hz);
Console.WriteLine(
''PSC: ''
+ prescaler);
Console.WriteLine(
''Period: ''
+ period);
Console.WriteLine(
''Clk: ''
+ clk);
Console.WriteLine(
''Scale: ''
+ scale);
if
(prescaler == 0)
if
// Avoid Overflow...
prescaler = clk;
period /= scaleMHz;
duration /= scaleMHz;
else
prescaler = 1;
period = period * clk / scaleMHz;
duration = duration * clk / scaleMHz;
else
while
// Prescaler too Large...
if
break
prescaler >>= 1;
period <<= 1;
duration <<= 1;
Console.WriteLine(
Console.WriteLine(
+ PrescalerFromFrequencyAndClock(period, frequency_Hz));
if
// 16 bit timer
while
(period >= 0x10000)
// period too large
if
break
prescaler <<= 1;
period >>= 1;
duration >>= 1;
Console.WriteLine(
Console.WriteLine(
Console.WriteLine(
Console.WriteLine(
''PSC: ''
+ (prescaler) +
'' - sometimes incorrect, calculated Prescaler is best used.''
Console.WriteLine(
''ARR: ''
+ (period - 1));
Console.WriteLine(
''CCRx: ''
+ duration);
Console.WriteLine(
private
static
uint
double
f,
out
ScaleFactor scale)
if
(f >= 1000.0)
return
uint
if
(f >= 1.0)
return
uint
return
uint
private
static
uint
double
period,
double
frequency)
return
uint
uint
)ClockSpeed / ((period) / (1 / frequency))) + 0.5) - 1);
private
static
double
double
return
double
)scale) / period);
private
static
uint
double
dutyCycle,
double
period)
if
(period <= 0.0)
throw
new
if
(dutyCycle < 0.0)
return
0;
if
(dutyCycle > 1.0)
return
1;
return
uint
private
static
double
double
period,
double
duration)
if
(period <= 0.0)
throw
new
if
(duration < 0.0)
return
0.0;
if
(duration > period)
return
1.0;
return
This code is generating the correct Values for Period, Duration and most importantly the Prescaler which is the value I was having the most problems with.
This code is modified from the Microsoft PWM and GHI electronics Open Source to suit my needs and hopefully help others out.
All the Best
Chris
‎2014-10-06 2:36 PM
RCR = 16-bit repetition counter (where present)
8-bit, on TIM1 and TIM8 on STM32F4 per RM0090
- « Previous
- 1
- 2
- Next »
