2024-05-01 8:00 AM
Hi all,
Is there a Modbus tcp/ip Server (Slave) and client (Master) examples for STM32 Nucleo F429ZI board or any other similar boards?
Thanks,
2024-05-29 4:01 AM
Currently, we do not have any examples implementing MODBUS protocol over TCP/IP. After doing a quick search, I found the links below that I think could help you. You could try and salvage what you can and adapt it to the board you are using.
I also suggest you take a look at LWIP TCP client/server examples for other boards from our STM32Cube FW package (for example LwIP_TCP_Echo_Client, LwIP_TCP_Echo_Server) as you could use them to extract a template code for client/server communication.
Best regards,
2024-05-29 4:01 AM
Best regards,
2024-07-21 2:22 AM
Hi data_cracker
I've just come across your question - I'm trying exactly the same thing, did you make any progress on your project with Modbus TCP on Nucleo?
