2010-09-08 6:27 AM
STM32, Keil MDK-ARM cannot debug, seems to try and run from SRAM
2011-05-17 5:06 AM
Found out what the ptoblem is.
We are using an external watchdog. pPoduction fitted and alternative part. If I disable the watchdog circuit I no longer have the problem. Interesting that it caused such odd things to happen especially in debug mode. The two parts spec looks more or less identical but there is clearly a difference. Thanks to all that read my message. Regards Clive
