2008-04-13 9:14 AM
STM32 Flash Programming
2011-05-17 3:29 AM
Do anybody know how to program the STM32 flash using Flash loader Demonstrator?
I am able to erase but when downloading it says Erasing failed and stops. What is the main difference b/w upload and download in Flash Loader demonstrator.2011-05-17 3:29 AM
I think the following document would be very helpful, Please try to follow steps in the document and keep me informed. http://www.stmicroelectronic.com/stonline/products/literature/um/13916.pdf Regards, Ibtissem.2011-05-17 3:29 AM
Thanks. But I knoe this before n followed the steps as they are. But the same problem persists.2011-05-17 3:29 AM
I got the same problem. Now my evaluation board is clear and resisted for downloading.
2011-05-17 3:29 AM
I am programming the chip directly, not using any evaluation board.
If anybody have the solution Plz let me know. Thanks in advance2011-05-17 3:29 AM
Hi all,
Check if your Flash is protected either Read-out-protected or Write protected, may be this is why you can not read or program it ? Hope this helps you. By the way , ST is preparing a new enhanced version of the existing Flasher demo with more features to be released this month. Cheers, STOne-32.
