STM32 firmware upgrade by USB pendrive
kltan47
Posted on September 21, 2010 at 10:41
Andrew Neil
Posted on May 17, 2011 at 14:08
There are several App Notes on IAP:  the only difference is the way in which you transfer the data to the chip - the IAP process is the same irrecpective of the data transport mechanism.
Similarly, the data transport mechanism is not dependent on the nature or purpose of the data.
Hence you can look at any IAP app note or example to see how to do IAP, and any USB Mass-Storage Host example to see how to do a USB Mass-Storage Host.
Note, of course, that you will need a USB Host in order to read a USB drive...
