2011-11-28 7:54 AM
I am unable to connect the stlink debugger using stlink utility program. My board contains stm32f103ZET6 controller, 512KB flash, 2K per page, I am unable to read device information. But i am able to connect my other board with stm32f103R8T6 to stllink debugger and able to flash and debug, Is it possible to use stlink debugger with stm32f103ZET6. pls help.2011-11-28 8:59 AM
Same issue as your previous post, or something else?
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/stlinkv2 debugger unable to connect&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx¤tviews=66]Here The ST-LINK should work with all the STM32F1xx series parts. You'll need to be more specific about your system, and the problems you are having with it. Make sure the ST-LINK has the most current firmware, for instance.
