STemWin problem: EDIT text bug
Posted on September 25, 2017 at 21:42
I've got a bug with the text of the Edit box. It show's strange chars or drawings, maybe another language font. I'm using the emwin with the SSD2119 driver. All other fixed texts and labels are correct (see the attached images).
Does some one have an idea why this happens?
I've used the same code with ILI9341 and worked perfectly.
  Using:
  STemWin532_CM4_Keil
  STM32F4-DISCOVERY
  SSD2119 LCD DRIVER
   Not using any RTOS.
Thank you in advance.
Posted on September 25, 2017 at 23:30
Sorry for Boring you again Angelis, and thank you for the answer by the way,
I've changed the value of the register R11, of the SSD2119, from 0x685C to 0x6874 and then it draw correctly.
Looking to the photos I noticed that the numbers appears that has been drowed messy, Changing the scan registers, ID[0:1] and AM, I found that this register only affects the Edit box object (strange, isn it!)
Thanks,
________________
Attachments :
edit box fixed.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyPG&d=%2Fa%2F0X0000000b7C%2Fp0eXde0GRONg0cA72OUoMQJ_X1sF9pyiARs9385fjtc&asPdf=false
R11 ENTRY MODE.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyAn&d=%2Fa%2F0X0000000b7A%2FUbAaToD0PFU6B4FDd.mAPM0pNiyJyOWZ4ol8_8z09EQ&asPdf=false
Posted on September 25, 2017 at 22:07
Hello!
Is the amount of memory allocated inside CUI_conf.c file, sufficient?
#define GUI_NUMBYTES  xxxx
Regards.
vf
Posted on September 25, 2017 at 22:14
Yes, it is.
#define GUI_NUMBYTES 1024 * 80
and there is only one screen.
________________
Attachments :
2017-09-25 17.18.30.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyHi&d=%2Fa%2F0X0000000b7D%2FjBt3LnLhmy2ETWdZNj_B7QMNBVNcS0IzJCfIEUG6y.U&asPdf=false
Thanks,
________________
Attachments :
