2011-05-09 03:12 PM
Stack pointer is setup to incorrect alignment?
2011-05-17 05:34 AM
You should probably download and use the VL Discovery board's firmware library, using the classic library for the original STM32F10x parts will probably introduce a bunch of problems with the PLL and Flash Wait States. The STM32F100 only runs at 24 MHz, without wait states, or flash prefetch.
