2009-05-07 03:28 AM
ST I2C driver problem
2011-05-17 04:11 AM
hi,
I'm tested i2c driver library of ST in polling and interrupt mode, and see if slave NACKed the transmission not complete and cpu stoped on while loops. also some events checked in wrong states. I'm testing i2c on at24c256 and adt7467 with problem on both of them. can anyone help me? :(2011-05-17 04:11 AM
We had quite a lot of problems with the I2C core in master and in slave mode. The I2C core seems to have several problems, which causes illegal states.
I would strongly recommend to use a combination of IRQ and DMA, like used in the latest versions of the examples.
