GPapa.7
SQLite on STM32F7 series
  • March 26, 2019
  • 3 replies
  • 1263 views
I'm trying to implement a DataBase connection with STM32F779NIHx.
I included the sqlite sources but received an error because the ioctl.h file is not present within the STM32F7XX HAL Driver. Where can I retrieve it?
After Forever
Senior III
March 26, 2019
SQLite doesn't know about your underlying storage layer. You'll have to port SQLite's VFS (virtual file system) interface to your microcontroller.
https://sqlite.org/c3ref/vfs.html - about VFS
https://sqlite.org/custombuild.html - about custom builds, also about porting requirements
[Click Show More]
I have to say that I'm not sure if STM32F7 can cope with SQLite. I don't know the library's minimum RAM/Flash requirements, but judging from poor search results with "sqlite stm32" or "sqlite freertos" keywords I am not too optimistic.
GPapa.7
GPapa.7Author
Thanks for your answer.
Second your opinion, is it possible upload a database on the STM32 on board SD card and communicate with it?
MikeDB
Senior II
March 26, 2019
Definitely possible but might be slow. I suspect you'd be better off with an ARM A series device where all of the work will have been done before by someone.
