SPI Miso pin
A.Caliskan
hello , ı use stm32h750vb
I m trying work spı,I'm trying to raise the miso pin at the beginning of the dialog, I'm wondering how you can do it.
MISO cannot be directly controlled, nor does it need to be, as the value only matters on clock transitions.
Use the pin in GPIO mode if you want explicit states.
