2015-12-17 12:18 AM
Before I update my windows 8.1 to 10, STMStudio worked. After update and installation java 64bit it doesn't start. I have tried reinstall STMStudio, uninstall and install java but it still doesn't work. Other java aplications like eclipse or CubeMX work fine. Anyone know how to solve this problem? #stm-studio #java2015-12-18 02:10 AM
Hi michal.l,
Could you precise version of both STMStudio and Java?-Shahrzad-2015-12-18 02:46 AM
the current version of STMStudio requires the java 32 bits version to be installed, and does not work with the 64 bits version. Note also that with java-1.8 the shortcuts for the STMStudio are badly computed by the installer; the path to javaw.exe should be manually modified afterwards in order to point to the real location on disk of javaw.exe. Those issues will be fixed in a next version planned for Q1-2016.2015-12-21 07:03 AM
Thanks a lot SC. I have changed path to javaw.exe and STMStudio works.
