2016-10-01 02:37 PM
Hi ,
I'm using STMF303. I need to run the bootloader through canbus, but it doesn't support this. Can I download program through canbus data while its running? (So through software ) Is it possible?Regards.2016-10-01 07:28 PM
You should be able to code your own loader to perform an IAP solution
