simple stm32 c question ?
jbl_raw
Posted on May 10, 2013 at 00:34
what is this 1ul and 2ul and 3ul
examble
 RCC->AHB1ENR  |= ((1UL <<  0) );              /* Enable GPIOA clock         *
  GPIOA->MODER    &= ~((3UL << 2*0)  );         /* PA.0 is input              */
what is the new value for   RCC->AHB1ENR and  GPIOA->MODER
#c-basics #off-topic
9 REPLIES 9
Posted on May 10, 2013 at 00:40
UL means the number is handled as an Unsigned Long,
RCC->AHB1ENR  |= 0x00000001;
GPIOA->MODER  &= 0xFFFFFFFC; // mask off low two bits ie ~0x00000003
The final state will depend on the initial state of the registers.
jbl_raw
Posted on May 10, 2013 at 15:28
thank you very much
but how you convert this (3UL << 2*0)   and this (1UL <<  0) to number !
Posted on May 10, 2013 at 15:53
I'm not sure I understand the question. The compiler parses suffixes which imply type information which it uses to do the computation, which can be different from the type it is later stored in, or other variables used in the computation. (Like using L to specify a long, on a compiler that would normally hold the value in 16-bit, or F to specify a float rather than a double)
(3UL << 2*0)
3 << 0
3
~3 is equivalent to 3 ^ 0xFFFFFFFF, ie the inverse or logical NOT
A quick Google
http://www.parashift.com/c++-faq/numeric-literal-suffixes.html
http://hackipedia.org/Platform/3D0/html%2c%203DO%20SDK%20Documentation/Type%20A/tktfldr/arrfldr/1arrg.html
Andrew Neil
Evangelist III
Posted on May 11, 2013 at 00:25
Note that none of this has anything to do with the STM32 - it is all just normal, standard 'C' syntax.
Time to dust-off that 'C' textbook...
http://blog.antronics.co.uk/2010/12/12/things-you-shouldve-learned-in-c-class-0-introduction/
Posted on May 11, 2013 at 14:33
The code is an example out there for the chip, it's not an unreasonable question, we want to cultivate this as a safe place to ask question, or seek clarifications.
Andrew Neil
Evangelist III
Posted on May 12, 2013 at 19:00
Yes;  but it's important to understand that this is just standard'C' syntax - not something that's in any way specific to the STM32 itself.
lakhi48
Posted on June 18, 2014 at 15:21
Hello all
I am new with ST micro controller,I have been designing a circuit bases on STM32F302VBT,
Can anybody guide me from where i can get the demo code or start up code or example code
bd_india
Posted on June 18, 2014 at 16:59
Hello Lakhwinder Ji,
Go to below link & download the example codes configured 4 different IDE's.
http://www.st.com/web/en/catalog/tools/PF258154
For more help/assistance please send me an email on monu.yadav@yosun.com.sg
Posted on June 18, 2014 at 17:13
How to start a new thread
