SIGFOX_API_send_frame = SFX_ERR_SEND_FRAME_SEND_UPLINK
‎2018-03-15 2:29 AM
Hello
When i try to use SIGFOX_API_send_frame. I receive SFX_ERR_SEND_FRAME_SEND_UPLINK as error. but i don't really understant the meaning. Could you give me more details about this error and a way to solve it?
By the way the Sigfox example work si it's not a jumper problem.
Reis Jonathan
‎2018-03-15 7:18 AM
https://ask.sigfox.com/questions/5004/when-i-try-to-use-sigfox-api-send-frame-i-receive.html
When cross-posting the same question to multiple forums, always post links - so that people can see the full story, and not waste time repeating what's already been said.
Are there are descriptive comments along with the definition of the
symbol?
‎2018-03-15 8:24 AM
I'll do it next time thank's for the advice.
Descriptive comment is 'Send uplink frame failed '.
‎2018-03-15 9:20 AM
Why not do it now?
Just go back to the other thread, and add the link.
Hmm ... whoever thought that was useful should be shot!
I guess you'll just have to trace through to find what could cause it ...
Do you have a working example to compare against?
EDIT
Here we go - illustrating the importance of you providing links between your two threads:
I see in the other thread that you do, indeed, have a working example - so use that as a reference to see where you're going wrong...
‎2018-03-15 9:30 AM
Because you already did
I mean, you need to add a link to this thread in your thread on the Sigfox forum.
Currently, that thread just stops dead - you need to tell people where you've gone to!
i mixed this example with a LoRa program
right - so, in doing that, you have broken the Sigfox.
Does the LoRa still work?
i just try to know where to look
In the other thread, you said you have
a STdiscovery kit the 'STM32L072CZY6TR' MCU that include a 'SX1276' chip
It always helps to give a full part number & link so that people know exactly what you're talking about.
Do you mea
n this:
http://www.st.com/en/evaluation-tools/b-l072z-lrwan1.html
That has a built-in debugger - so you can step through your code and see what's happening!
‎2018-03-15 9:57 AM
Why not do it now?
Because you already did. (i posted this only here and on the Sigfox forum).
I do have an example but i mixed this example with a LoRa program and there is a lots of files and i just try to know where to look. If i could know witch variable the HEX files (that support sigfox) used it would be more easy for me to find it. This is the reason i ask to know more about that error message maybe it could explain me where the problem is.
‎2018-03-15 10:55 AM
Ok I know understand what you mean and I did it.
yes, the Lora work.
Do you mea
n this:
Yes, it is the discovery I get.
I debug it myself before I come here to ask some help and don't really understand where the problem comes from. So neither you neither Sigfox know what this error really means?
‎2018-03-15 3:54 PM
Kling.Brian
‌ - why is this flagged as 'Assumed Answered'?It seems an unwarranted assumption ...
‎2018-03-15 4:53 PM
No, I don't know what the error means.
I am suggesting the kinds of steps I would take in addressing such a problem.
‎2018-03-16 12:03 AM
There is a setting in the system that if there are x number of replies it is 'Assumed Answered' - we have altered the trigger threshold so this shouldn't occur very often.
