Shutdown mode problem with STM32L4
‎2017-04-10 12:56 AM
I have a board with the STM32L476RET6, the shutdown mode worked a time and now it resets just after the STM32 enters in shutdown mode. I tried the same program with another same board and the problem does not appear.
I thought it was a problem with an interrupt but even if I disable all interrupts, the problem persists. I also disabled RTC clock.
__disable_irq();
__disable_fault_irq(); HAL_PWREx_EnterSHUTDOWNMode();Thank you for your help,
Best Regards,
Jonathan
‎2017-04-10 1:42 AM
Hi
CONSTANT.Jonathan
,I tried the same program with another same board and the problem does not appear.
may be you have to verify your PCB, refer please to
- also refer to
SHUTDOWN example under the STM32L4 firmware package :
STM32Cube_FW_L4_V1.7.0\Projects\STM32L496ZG-Nucleo\Examples\PWR\PWR_SHUTDOWN ,this example shows how to enter the system in SHUTDOWN mode and wake-up from this mode using external RESET or WKUP pin.
-Nesrine-
‎2017-04-10 4:19 AM
Hi Nesrine,
Thank you for your answer. I double-checked my PCB and all seems good. I used the shutdown example from STM32Cube for my project, I thnik the code is correct because it worked until now. I tried to disable all wakeup pins and I get the same problem: the system resets. Here is my code.
int main(void)
{ HAL_Init();powerState = OFF;
/* Enable Power Clock */
__HAL_RCC_PWR_CLK_ENABLE(); HAL_PWR_EnableBkUpAccess();while(1) {
loop();
void loop()
{ switch (powerState) { case OFF: {__disable_irq();
/* Clear wake up Flag */ __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF1); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF2); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF3); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF4); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF5); HAL_PWREx_EnterSHUTDOWNMode();break;
‎2018-01-02 4:25 AM
Hi Constant,
I have the same problem. Have you foud a solution?
Marco
‎2018-01-03 10:21 PM
hi i too have same issue any body found solution ,please help me
‎2018-01-04 1:21 AM
HI Dijith,
I partially solved the problem adding HAL_PWREx_DisableInternalWakeUpLine() just before HAL_PWREx_EnterSHUTDOWNMode();
It seems working on my setup.
Marco
‎2018-01-04 1:28 AM
thank you,let me try now it self . next stage i need to use internal RTC alarm to wake up every 2 minutes .thanks for your support.please give me suggestion if u r free
‎2018-01-04 4:52 AM
hi marco,
see the code i used,
- Set NVIC Group Priority to 4
- Low Level Initialization */ HAL_Init();/* Configure the system clock to 80 MHz */
SystemClock_Config();/* Configure LED1 and LED3 */
BSP_LED_Init(LED2); // BSP_LED_Init(LED3);/* Enable Power Clock */
__HAL_RCC_PWR_CLK_ENABLE(); HAL_PWR_EnableBkUpAccess(); /* Check if the system was resumed from shutdown mode, resort to RTC back-up register RTC_BKP31R to verify whether or not shutdown entry flag was set by software before entering shutdown mode. */ if (READ_REG(RTC->BKP31R) == 1) { WRITE_REG( RTC->BKP31R, 0x0 ); /* reset back-up register */ out_of_shutdown = 1; /* out of shutdown detected */ }/* Insert 5 seconds delay */
HAL_Delay(5000); /* Disable all used wakeup sources: WKUP pin */ HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN2); /* Clear wake up Flag */ __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF2); /* Enable wakeup pin WKUP2 */ //HAL_PWR_EnableWakeUpPin(PWR_WAKEUP_PIN2_HIGH); /* Set RTC back-up register RTC_BKP31R to indicate later on that system has entered shutdown mode */ WRITE_REG( RTC->BKP31R, 0x1 ); __disable_irq();__disable_fault_irq();
/* Clear wake up Flag */ __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF1); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF2); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF3); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF4); __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF5); HAL_PWREx_DisableInternalWakeUpLine(); /* Enter shutdown mode */ HAL_PWREx_EnterSHUTDOWNMode();can u check is thr anything wrong?
‎2018-01-05 12:52 AM
Hi Dijith,
actually your code looks correct. In my code I have also disabled the wakeup line. My code is for an STML4xx microcontroller, so the recovery from the shutdown can be managed by RTC or 5 GPIOs.
In my application recovery from the shutdown is given by PC13 so my complete shutdown code is this one:
HAL_PWREx_EnableGPIOPullUp(PWR_GPIO_C, PWR_GPIO_BIT_13);
HAL_PWREx_EnablePullUpPullDownConfig();/* Disable used wakeup source: PWR_WAKEUP_PIN2 */
HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN1); HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN2); HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN3); HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN4); HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN5);/* Clear all related wakeup flags */
__HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF2);/* Enable wakeup pin WKUP2 */
HAL_PWR_EnableWakeUpPin(PWR_WAKEUP_PIN2_LOW);HAL_PWREx_DisableInternalWakeUpLine();
/* enter shutdown */
Let me know if this help you.
Marco
‎2019-02-12 7:29 AM
I have same problem on STM32L433RCI.
After entering shutdown mode microcontroller restarts every other time.
1 attempt: reset
2 attempt: stays in shutdown
3 attempt: reset
4 attempt: stays in shutdown
my code is
void enter_shutdown (void)
__HAL_PWR_CLEAR_FLAG(PWR_FLAG_WU);
