Second I2C bus generating 60 Hz square wave at SCL
Eric P
Posted on March 15, 2018 at 14:51
I have successfully implemented an initial I2C bus (I2C1) in my custom board design (using STM32F405).  I then added a second I2C bus (I2C2) to my design and have initiated it and set it up identical to I2C1.  The first bus continues to operate correctly (sending a clock signal out at 100 kHz).  I've specified the same clock frequency for the second bus.  However the SCL pin only puts out a *constant* 60 Hz square wave.  What could I be doing wrong?
#dual-i2c #i2c #scl
waclawek.jan
Posted on March 15, 2018 at 15:50
We don't know.
Read out and check/post the relevant GPIO and I2C registers content.
