SDADC inaccuracies when enabling multiple SDADC peripherals
brandon2
Posted on October 07, 2015 at 16:16
The original post was too long to process during our migration. Please click on the attachment to read the original post.
1 REPLY 1
Danish1
Lead II
Posted on October 07, 2015 at 21:35
I suspect that you will get interference between AD channels if your Analog Vdd and/or VRef are not sufficiently well-regulated.
You could try boosting the decoupling capacitor on that line by (say) 10 times, and see if that makes a difference.
Or using a higher-performance voltage regulator (many of the ''low-power'' ones are fairly slow, whereas you need to regulate away noise at the oversampling frequency).
Hope this helps,
Danish
