Saving some data in RAM between Reboots.
‎2020-01-07 10:44 AM
I am trying to add s RAM section at the end of the RAM to save
some data (states) between warm reboots, when the watchdog kicks due some
wiring problems (i2c).
I changed the ld file as:
- I reduced the stack -2k
- I reduced ram -2k
- I created a RAMAUX and afferent section.
/* LD file ... */
/* _estack = 0x20028000; -- taken out */
_estack = 0x20027800; /* new stack - 2K */
MEMORY
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 158K /* was 160 now is - 2K */
FLASH (rx) : ORIGIN = 0x8000000, LENGTH = 512K
AUXRAM (rx) : ORIGIN = 0x1FFFF800, LENGTH = 0x800 /* use 2 K */
/// then later on at the end.
.my_ram : {
KEEP(*(.my_ram))
} > AUXRAM
/* Remove information from the standard libraries */
The program wont start.
I hangs in the startup file here:
The start hang here. Anything else I am missing.
The intend is to access it in C like
uint32_t ram_end __attribute__((section (".my_ram"))) ;
static void* __attribute__((optimize("O0"))) _ram_storage(void)
void* ptr = (void*)&ram_end;
return ptr;
Thank you,
... addon
sometime this pops up from atolic
RAM
STM32L4 series
‎2020-01-07 11:46 AM
something like
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM) + LENGTH(RAM); /* end of "RAM" Ram type memory */
_Min_Heap_Size = 0x200 ; /* required amount of heap */
_Min_Stack_Size = 0x400 ; /* required amount of stack */
AUXLEN = 2K;
/* Memories definition */
MEMORY
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 160K-AUXLEN
AUX (xrw) : ORIGIN = ORIGIN(RAM) + LENGTH(RAM) LENGTH = AUXLEN
‎2020-01-07 10:49 AM
The AUXRAM can't be below 0x20000000, you're recovering from the END of memory
The Stack moves downward, so the base for both stack and auxram should be 0x20027800
something like
AUXLEN = 2K;
MEMORY
‎2020-01-07 11:53 AM
RESOLVED !
Many thanks.
This solved my problem.
... and the elegance of the provided code. Thank you again.
