Sample codes for STM32F051C6
TH U
Dear sir/madam,
I want sample codes for this controller i.e. STM32F051C6. Please provide the sample codes for following parameters.
  1. Timer
  2. PWM
  3. DAC
  4. Display 8x2
Thanks and Regards,
Thippeswamy H U
AvaTar
Lead
You mistake ST's public E2E forum with a fee-based support hotline.
The users/volunteer here will not do the work for you, unless you share the gains of your commercial project.
The F051 is a seasoned MCU, example projects can be downloaded from ST's website. Both SPL based, or Cube. https://www.st.com/en/microcontrollers/stm32f0-series.html?querycriteria=productId=SS1574
BTW, uploading full contact information in public fora is usually not a good idea.
Thank you. I have removed the contact details, I was not aware of about its a public network.
You can approach ST directly, via FAE or distributor. They might be quite interested in getting your project started.
Get to the e2e forum with technical questions, and you get help.
