Same Memory base address In DMA
‎2017-08-09 5:01 AM
Hello
Can i use same memory base address in two dma (dma1 ,dma 2) for transfer date to Peripheral?
DMA_DeInit(DMA1_Channel7);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) & GPIOA->ODR; DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)BUFFER;DMA_DeInit(DMA2_Channel7);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) & GPIOB
->ODR;
BUFFER
Is it have any problem?
‎2017-08-09 5:30 AM
This kind of memory-to-memory must be done with DMA2 to access GPIO residing on the AHB
‎2017-08-09 5:19 AM
Yes.
There may be a different one: In 'F2/'F4/'F7, the peripheral address of DMA1 must be on APB1.
‎2017-08-09 5:30 AM
‎2017-08-10 2:36 AM
