RTC second advanced and SSR greater than PREDIVS
I am using stm32f779 RTC upto subseconds granularity that is using SSR register value for giving upto milliseconds level of time output .
The scenario is such that there is external time source ( network clock) to which I synchronise RTC by updating it's time every hour in order to compensate for time delay or advance due to RTC clock drift.
I have managed to get advance and delay of time based on drift into time, date and sub second registers using synchronisation section guidelines of Stm32f7 reference manual.
Issue is on using SUBF bits of SHIFTR register when we advance RTC SSR register our second get one plus ahead of intended time i.e if we updated with 6 second it becomes 7 and our SSR register is above PREDIVS on each shift operation.
Now I understand that is expected behavior based on Reference manual but there is no mention about how to deal with this situation.
Does only subtracting one from seconds will be enough after each such shift operation or we need to do something about bringing SSR value back to Less than or equal to PREDIVS register value?
