rtc calendar application, urgent
Options
‎2011-02-11 8:04 AM
Posted on February 11, 2011 at 17:04
Options
‎2011-05-17 5:24 AM
Posted on May 17, 2011 at 14:24 Assuming your system starts up with the right oscillators and peripheral clocks enabled; to write to the backup registers the following should be sufficient: PWR_BackupAccessCmd(ENABLE); // allow access to Backup Registers BKP_WriteBackupRegister(BKP_DR2, 0x0005); // write value 5 to BKP_DR2 [PWR_BackupAccessCmd(ENABLE); is probably equivalent to PWR->CR |= PWR_CR_DBP;]. -Chris
Options
‎2011-05-17 5:24 AM
I am storing date in backup registers. BKP2,3,4
Or use a 32-bit time scale like UNIX time. And you wouldn't have to watch for the RTC wrapping every 24 hours.
