RS485 modbus Communication
‎2013-03-25 5:01 AM
i am using the stm32f107rc controller for rs485 communication. i am trying to transmit a set of data through usart1 from the controller, but some byte of data are missing at the destination so pls let known where i am doing mistake............Thank u in advance
‎2013-03-25 12:06 PM
So what is received at the other end, may be you should be explicit about what was sent, and what was received. I'd dig though the code, but I hate this register level crap.
Perhaps also consider if you're using the TXE or TC interrupt, and be consistent about it.Up vote any posts that you find helpful, it shows what's working..
‎2013-03-25 10:47 PM
Thank u..... The problem as solved........
‎2013-05-06 8:00 AM
‎2013-05-06 8:02 AM
‎2013-05-06 8:40 AM
You have a question?
