Question of STM32F373 SDADC Multi channel concept
Sangkyu Kim
Posted on April 04, 2017 at 15:08
I want to use multi channel SDADC in STM32F373.
First,
Can I use Multi channel  in SDADC1 using regular conversions?
In case of SARADC, it is operating scan mode. But i can't find scan mode in SDADC.
Second,
If regular conversions is not provide scan mode,
only injection mode provide
Multi channel?
Third,
There is no example code about Multi channel SDADC.
Can you give me some example code using
Multi channel SDADC?
#stm32f373 #sdadc
Imen.D
Posted on April 04, 2017 at 15:44
You can refer to the
http://www.st.com/content/ccc/resource/technical/document/application_note/a0/8e/94/50/ae/d2/4b/5e/DM00124123.pdf/files/DM00124123.pdf/jcr:content/translations/en.DM00124123.pdf
and
http://www.st.com/content/ccc/resource/technical/document/application_note/d9/90/d7/70/7c/ff/45/6d/DM00070480.pdf/files/DM00070480.pdf/jcr:content/translations/en.DM00070480.pdf
Application note Getting started with STM32F37x/38x SDADC (Sigma-Delta ADC)
The
SDADC examples are available as part of
the
STM32F373 SDADC
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-libraries-expansions/stsw-stm32114.html
package and Standard Peripheral Library STSW-STM32115 following the UM1565 'Description of STM32F37xx/38xx Standard Peripheral Library' to have more details on how to use this driver.
You'll probably want to review SDADC examples as you can find under STM32CubeF3 firmware:
STM32Cube_FW_F3_V1.6.0\STM32Cube_FW_F3_V1.7.0\Projects\STM32373C_EVAL\Examples\SDADC
Hope this help you.
Imen
Imen
Posted on April 04, 2017 at 16:18
Thank Imen D
I saw your app note and example code.
But i can't find about multi channel using one sdadc
