Problem with stm cubeMX and keil
Options
2015-02-10 12:46 AM
Posted on February 10, 2015 at 09:46
Hi to all, i use CubeMX and Keil 5.12 with Stm Nucleo, STM32L152RE, all work well.
Yesterday I upgrade the CubeMX to 4.6 version, later this upgrade i have this error: --- The Project references devices, files or libraries that are not installed Download and Install Third Party Device Support for ''STMicroelectronics :STM32L125RE'' (Device not included in Legancy Device Satabases)--- i upgrade Keil to the 5.13 version, in Pack Install i uninstall and later install the packeg for StM32L152 but don't work. if I open blink example all work well, if i use other easy example all work well, but if i use the code of CubeMx i have this message error. can you help me? best regards Antonio
1 REPLY 1
Options
2015-07-01 2:40 AM
Posted on July 01, 2015 at 11:40 Hello we are unable to reproduce your issue: Trying to reproduce: using a project generated by MX but with keil::STM32L1xx_DFP pack already installed, everything goes well and no error message appears. Remove the keil pack and try again: the error message appears asking to install the correspanding pack. Your issue is likely due to the fact the keil pack is not properly installed/missing. Best regards
