printf double precision but getting just single precision
‎2017-06-12 11:51 PM
I am working on a firmware for the STM32F765.
This MCU was chosen because of its double precision floating point capabilities.I manged to configure the FPU/Compiler (ARM GCC 5.4) to genertate correct DP native assembly instructions.When debugging, I can verify correct DP calculations.The only thing I cannot manage is to printf results in double precision.
I have tried the formatters %f and %lf but on every printf only single precision is printed out (correctly rounded results but with too less digits).I am using newlib speed optimized (NOT nano), but also the lib stdc++ does the same.Has somebody ever seen the printf output in double precision for an embedded ARM Cortex-M7 code with GCC & if yes, how do I get it running ?Thank you in advance,
GahlenSolved! Go to Solution.
‎2017-06-13 1:02 AM
Take a look at the POSIX spec. of the
printf()
style functions (e.g. the Linux manpages).For the e,f and g format, it states '...if the precision is missing, it is taken as 6;'.
Try, for example, '%.10lf'
‎2017-06-13 1:02 AM
printf()
‎2017-06-13 2:03 AM
'man fprintf' on my Linux system tells to use '%Lf' or '%llf' for long double arguments.
‎2017-06-13 3:33 AM
Thank you very much! I did not know this, but exactly this was needed to print out the required precision.
‎2017-06-13 4:39 AM
I just want to print out 64bit double values with many fractional digits. These have the printf formatters %f or %lf.
What you mean with %Lf or %llf is 128bit quad precision that the Cortec-M7 cannot handle natively.
‎2017-06-13 4:58 AM
And I'm pretty sure most scanf/printf implementations (libraries) for Cortex M cannot handle long double types.
‎2017-06-13 10:29 AM
I've never understood the use case for the single precision one....
Glad it was just a format issue, the default will be misleading, I tend to prefer specifying a very large number of decimal place, and using the '%le' variant.
Unfortunately the FPU designs of recent years don't hold intermediate values at higher precision, and this is compounded by the availability of only simpler intrinsic functions.
‎2017-06-14 4:33 AM
I am 100% with you... what shall we do with just 7 decimal digits precision? -> single precision is just to have FP in the specs
unfortunately most programmers are not scientists at all; the current default value of 6 fractional digits is confusing in this situation because it let me thought that the output was single precision only
I was a little bit disappointed when I read that the Cortex-M DP FPU has 64bit only, even for the internal intermediate values; I can remember that in the late 80s Motorola's FPUs already applied extended precision for intermediate representations...
I would be glad just to have native DP sin and cos functions for DQ transformations...
‎2017-06-14 5:18 AM
I assume three reasons:
- the supposed use cases for a general-purpose microcontroller,
- the costs (design & silicon),
- differentiation of markets (avoid competition with Cortex A).
‎2017-06-14 7:30 AM
- Cortex-A comes with frequencies that is far out of range for Cortex-M, even in forseeable future
- silicon area for a better FPU sould be neglectable when it comes to costs of 8..10$ for an STM32F765 MCU
- currently the main reason probably is that ARM is not willing to offer a 1st class FPU for its M line (you alread said it), since STM 'only' adds their peripherals
- microcontrollers have been improved magnificently in this decade; I am sure that we will see ones with a full FPU and MMU soon
