porting mbed mfrc522 library to keil
mhdizgah
Posted on September 30, 2014 at 09:37
hi every body
i want to use mfrc522 mbed library in keil compiler & dont want to export codes directrly but i have some problem with these codes:
MFRC5h
class MFRC522 {
public:
* MFRC522 constructor
* @param mosi SPI MOSI pin
* @param miso SPI MISO pin
* @param sclk SPI SCLK pin
* @param cs SPI CS pin
* @param reset Reset pin
MFRC522(PinName mosi, PinName miso, PinName sclk, PinName cs, PinName reset);
* MFRC522 destructor
~MFRC522();
private:
SPI m_SPI;
DigitalOut m_CS;
DigitalOut m_RESET;
i know about classes & have some experiences in c++ compiler show errors about unknown type names :PinName, SPI & DigitalOut perhaps
<<code>> DigitalOut m_CS;<</code>> defines chip select pin as output & m_RESET is same but whats meaning of <<code>> DigitalOut m_RESET;<</code>>
? what does it work ? & whats function & type of PinName? what dose it do? whats differences between PinName cs & DigitalOut m_CS;
tnaks every body
</span>
#mbed.mfrc522 #stm32f103
0 REPLIES 0
