2010-08-20 1:02 PM
Please confirm my opinion about external interrupts
2011-05-17 5:03 AM
What does the Datasheet say?
(I've certainly used PC1 for an external interrupt)2011-05-17 5:03 AM
you should look at RM0008.pdf
Figure 21 read section 92011-05-17 5:03 AM
Well, thanks to everybody.
The guy was partly right. I really cannot use PA0 and PC0 together. Everything seemed so clear...2011-05-17 5:03 AM
You can have ''PA0'', ''PA1'', ''PC2'', ''PC3'', ''PA4'', ''PA5'' all enabled at a time, but not ''PC0'', ''PC1'' and inputs 0 and 1 are already assigned to Port A, but you can configure them later if all them are not used in same time. Cheers, STOne-32.
