on bootloader How to jump to my application ?
Pisut Temjitpakdee
Posted on April 30, 2017 at 08:50
Hello. I dev bootloader on stm32 F101 by STM32CubeMX , When I jump to my app from bootloader, It not work
My app  address 0x08002C00
This my code
https://gist.github.com/anonymous/503edbd8572ffb58db963e6bb531c1da
Posted on May 01, 2017 at 05:06
>>It not work
Yeah, that's not terribly illuminating. So if you use a debugger, and step into the code, what do you learn? Does it jump to a viable address? Does that look like the Reset_Handler code in your App? How deep does it get into the App code?
Posted on May 03, 2017 at 03:53
Clive One Thank you for the suggestion, I found issue in my App When Reset_Handler process in  SystemInit function It reset vector table to 0x08000000 but my app start 0x08002C00
