Noise on GPIO input pin
‎2016-04-25 10:16 AM
Hi.
I am using STM32F030 for my product. The GPIOs are configured as input and are connected to touch ICs. Sometimes on some boards i observe noise on the input pins. I connected the pin to scope and i see the line continuously fluctuating. My knowledge to hardware is limited. I have no idea why it behaves this way. My hardware engineer is not able explain the behavior. I have 12 GPIO inputs connected to such ICs but only one or two behaves like this. That too not on all the boards. My GPIO init isGPIO_InitStruct.Pin = GPIO_PIN_13;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
plz help..!!
Thanks!!
‎2016-04-25 10:26 AM
And is this coming from the Touch IC, rather than the STM32? Does it go away if you enable the pull up/down?
‎2016-04-25 10:29 AM
Yes its coming from touch ic.
I have not enabled pull up/down. I will check that.- Mark as New
‎2016-04-25 10:48 AM
Hi yafis.mohamed,
I recommend the application note'' Guidelines for designing touch sensing applications with surface sensors'' wich will be your support when developping using
http://www.st.com/web/en/catalog/tools/FM147/CL1794/SC961/SS1743/LN1734/PF258655
-Hannibal-
‎2016-04-25 10:55 AM
No. Enabling pull up/down is not stopping it.
Thanks!!!- Mark as New
‎2016-04-25 11:31 AM
Any other suggestions?
May be the touch ic is behaving weird. But this only happens to one or two. Rest all work fine.Thanks..!!!- Mark as New
‎2016-04-25 12:04 PM
I don't know, I have no familiarity with your design.
If you remove the other IC does that fix it, how about if you replace it?Up vote any posts that you find helpful, it shows what's working..
‎2016-04-26 2:07 AM
‎2016-06-01 7:09 AM
Hi. Sorry for the late response.
I too believe it is not the issue with STM32.The touch ic i am using is a auto-calibrating one. The part number is TTP223B.This behavior is observed after some time of power-on, like after a couple of hours.Thanks..!!- Mark as New
‎2016-06-04 5:29 PM
It's very hard to know what's wrong without having the full schematic and pcb layout. However, I would suggest two things:
1) Try to change the IC. If it's behaving strangely after a few hours of usage, it might be faulty. Also, veryify that you're not using it out of the recommended operating conditions, as specified in the datasheet. Having a faulty IC isn't very likely, though. 2) Maybe you have a component which is affected by a temperature rise on your board and leads to high noise. But since I don't have more information on your design, I really can't know. You should also try using this IC with other MCUs, with an arduino, etc., and see in which conditions the phenomenon occurs. PS: a picture of this ''fluctuation'' would be handy.
