no definition for ''__iar_data_init3''
Options
‎2015-11-20 5:14 AM
Posted on November 20, 2015 at 14:14
Hello everybody
I want to declare a vector to save data on it (in assembly code).I use this declaration: SECTION MYDATA:DATA (2) DATAResult DS8 3 ; allocates space (3 bytes)When I compile, IAR give me this error:Error[Lp001]: no definition for ''__iar_data_init3'' [needed to initialize section MYDATA (asm.o #6)] Anyone have any idea how to fix this?regards
Options
‎2015-11-26 8:14 AM
Posted on November 26, 2015 at 17:14
Hi engkyr,
If you didn't yet find a solution for this issue, I suggest you describe it inhttps://www.iar.com/support/#%21?tab=resources
.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Options
‎2015-11-27 2:55 AM
Posted on November 27, 2015 at 11:55
Thanks Mayla,
At the end I didn't use any directive. I did it ''manually''
