Need help on GPIO registers
‎2008-05-09 4:04 AM
‎2011-05-17 3:26 AM
STM32F103 is the first 32 bitter I am working on.. Can you guide me to online resources, which specify how GPIO port control registers are mapped, and their functions [ This message was edited by: goswamiarindam on 08-05-2008 13:28 ]- Mark as New
‎2011-05-17 3:26 AM
I have found the information on how GPIOs are mapped ... Can someone help me with information on how the control registers for GPIO work ... I am at sea here ..
I do not seek a detailed explanation on this forum ... But if you could paste a link here that gives me the info, that would help me a lot- Mark as New
‎2011-05-17 3:26 AM
I'm assuming you have the 'Reference Manual' (which details GPIO registers).
Try downloading the Firmware Library, and look at the two GPIO examples. This will make it easier to use GPIO if the reference manual isn't much help. Both are at: http://www.st.com/mcu/familiesdocs-110.html- Mark as New
‎2011-05-17 3:26 AM
Thanks Paul,
The code helped.- Mark as New
‎2011-05-17 3:26 AM
Here's some more ''first ARM'' guidance:
If you're like us - you will be struck by the seeming complexity, number and length of the signal/register definitions/declarations. Compared to your familiar 8-bit - the ARM is off-putting. Like you - we like to start by toggling a single I/O - but in the ARM world this is a big, big deal. And so much typing/cut->pasting... You've had to ask - WHY go thru all this? All the seeming complexity ''Opens the power, flexibility and performance of these GREAT, new micros! And once you go thru the required ''set-ups'' and definitions you will be able to re-use most. So it is primarily a ''one-time'' learning curve battle. Truth in Advertising - as your focus shifts beyond I/O you will AGAIN have to master pin, signal and register definitions. All of the flexibility causes an ''apparent'' significant increase in set-up/mode-selection etc. Here are some specific recommendations my firm employs: 1) Find someone who has recent, specific experience with your ARM family. Beg, trade, entice their assistance. Taking forever is NOT an option! 2) Buy proper, tested Eval boards - a very basic AND ST's teriffic TFT Eval board (if you can afford it). We've had better results with a very simple board - the more complex ones FORCE a level of expertise and understanding which is beyond 99% of new users. KISS ! 3) As a college instructor turned business owner - confine your learning, study sessions to short, regular ones with targeted, written goals. You can't master these chips with the ease of ''simpler'' ones from your past. 4) Find several others to ''co-learn.'' When you're hopelessly ''blocked'' the ''other guy'' often proves helpful. Too often - engineers ''Lone Ranger'' mentality retards their learning and career achievements. 5) Sorry - you have ''NO choice'' but to systematically read EVERY post in this forum. Posts range from ridiculous to expert - there is NO better way to get a real ''feel'' for the chips and development issues. 6) Many forum-posters have tremendous problems with self-produced boards. My firm calls this, ''Maximum Randomness!'' New hardware, new software, connection integrity, complex chip - you could not choose a path more destined to failure/frustration! KNOW what you're doing with the hardware OR software AND be sure of your smt production skills BEFORE attempting your own pcb design... Engineers/Programmers MUST value their TIME ! This forum is filled with talented, generous contributors. You should cover the ''basics'' before posting - provide complete data - and always ''close the loop'' so that our forum community LEARNS what worked/failed. blatant ''plug'' follows: As my firm has had much success following the above we will shortly be offering a basic STM Eval bd - with unique, mono Graphic Lcd - NAV Sw, & Soft-Keys priced at $39 Q10. A more complex board will continue the Nav Sw & Soft Keys - but include TFT: $99 Q10 ! Unlike existing Eval/Dev bds. - ours are intended for compact panel mount - achieving an economical, high performance GUI in mono or color...
