2017-09-26 12:27 AM
After migrating project from FW_L4 v1.8.0 to FW_L4 v1.9.0 there is mising line:
RCC_OscInitStruct.PLL.PLLM = 1;
in function
void SystemClock_Config(void)
MCU is STM32L486VGT.
Why this happened?
2018-02-06 05:25 AM
Hello
Mlinaric.Vinko
andBuga.D_niel
,Sorry for my late reply.
This issue about 'PLLM is no more generated' is fixed in the CubeMx version 4.23 asmentioned in the Release note of STM32CubeMX
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Frelease_note%2Fb2%2F02%2F4b%2Fe3%2F81%2F32%2F49%2Fc4%2FDM001076pdf%2Ffiles%2FDM001076pdf%2Fjcr%3Acontent%2Ftranslations%2Fen.DM001076pdf
.You can upgrade with the latest CubeMX release (version4.24).
Best Regards,
Jeanne
2017-09-26 12:49 AM
Hello
Mlinaric.Vinko
,Did you also update STM32CubeMX software? Which version you are using?
Best regards,Tilen
2017-09-26 01:35 AM
This issue is already raised internally to CubeMx team. We come back to you as soon as we have needed details.
Kind Regards
Imen
2017-09-26 02:57 AM
Please see:
2017-09-26 03:14 AM
Hello Tilen,
i'm using latest version MX Cube 4.1
Lep pozdrav,
Best regards,
Mit freundlichen Grüßen,
Vinko Mlinari�?
Razvojni inženir
Development engineer
T: +386 2 671 96 86
M: +386 31 395 335
vinko.mlinaric@seltron.si
Skype:
<http://www.seltron.si/>
Seltron d.o.o. | Tržaška cesta 85 A | SI-2000 Maribor | Slovenija
T: +386 2 671 96 00 | F: +386 2 671 96 66 | info@seltron.si | www.seltron.eu
________________ Attachments : image002.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyBo&d=%2Fa%2F0X0000000b7B%2FL_q3jNxZdrqqqpRd_wLBxHIs_Pou4XRSe8WTbDCnUms&asPdf=false2017-09-27 09:19 AM
This issue will be fixed in our next release.
Best regards
2018-02-06 05:25 AM
Hello
Mlinaric.Vinko
andBuga.D_niel
Best Regards,
Jeanne
2018-04-17 05:53 AM
This issue is back with CubeMX 4.25.
