MX 4.7.1 code generation bug
hbarta
Posted on May 10, 2015 at 14:29
Hi folks,
I used MX to generate code for a project based on the STM32F429I-DISCO board pretty much for the default I/O configuration. (IIRC I made no changes)
MX_FMC_Init() was declared but not defined.
Project Settings -> Project:
Toolchain: SW4STM32
Project Settings -> Code Generation:
 - Add Necessary Library Files
 - Keep user code ... and delete previously ... both checked
.ioc file attached.
Thanks!
hank
7 REPLIES 7
Rob.Riggs
Senior III
Posted on May 12, 2015 at 14:56
What operating system are you using?
chrif
Posted on May 14, 2015 at 17:39
I used MX to generate code for a project based on the STM32F429I-DISCO board with default configuration and toolchain SW4STM32, and MX_FMC_Init() was declared and defined.
Besides, I have loaded the .ioc in attachement, I generated code and MX_FMC_Init() is declared and defined. Also, It seems that sent project does not contain the default configuration.
hbarta2
Posted on May 14, 2015 at 18:08
Linux
Rob.Riggs
Senior III
Posted on May 18, 2015 at 04:41
That's a known issue.  STM does not test its tools on case-sensitive file systems.  As a work-around, mount up a VFAT or NTFS loopback filesystem and export the code there.  It will be fine.
hbarta
Posted on May 20, 2015 at 13:12
Thanks for the tip, Rob. Is this necessary only for the project directory or does the repository that MX uses also need to be VFAT/NTFS?
thanks,
hank
Rob.Riggs
Senior III
Posted on May 24, 2015 at 04:31
Just the project directory based on my experience to date.
stm32cube-t
Senior III
Posted on December 01, 2015 at 12:44
Dear users,
this issue will be solved in STM32CubeMX 4.12.0 release.
