Multiple pieces of (ST) literature says the code for the B-L475E-IOT01A2 will run on the B-L4S5I-IOT01A. It does not run Does anyone know what changes are required to '475 source code so that it can run on the '4S5? Thanks
MBlak.2
Guillaume K
What code for B-L475E-IOT01 did you use that does not run on B-L4S5I-IOT01A ?
It seems to be a third-party software using mbedOS and doing AI. I suggest you ask the developers of this product. maybe create an Issue in the github project.
