Maximum Safe voltage on GPIO Pin
‎2021-03-03 4:52 AM
I am a newbie here. I have purchased a STM32G071 Nucleo-64 development board. I wish to interface it to the 5 volts signal(s). The intended interface pins are PB1, PB3 and PB4. The Absolute Maximum ratings VIN states:-
1) Input voltage on FT_xx pins except FT_c = VDD + 4.0 max
2) Input voltage on FT_c pins = 5.5 max
3) Input voltage on any other pin = 4.0 volts max
My Question: -
What are FT_xx pins and FT_c pins? Its not mandatory to use the pins PB1, PB3 and PB4 as listed above, I can use a suitable alternative.
- Labels:
GPIO-EXTI
STM32G0 Series
‎2021-03-03 5:24 AM
These are the internal pin structures.
Please check STM32G071RB datasheet, Table 11, page 41.
‎2021-03-03 5:24 AM
