Maximum CPU Cycle for Which attempt to read the same flash memory bank stalls the bus.
Akash Saini
As per RM0456 Reference manual for STM32U5, any attempt to read the same flash memory bank stalls the bus. Can you please specify the maximum time/CPU clocks for which bus can be stalls.
Thanks,
Akash Saini
waclawek.jan
That depends on the operation on FLASH, for timing of those operations, see Flash memory characteristics chapter in datasheet.
